Rocker Arms.
Old Feb 27, 2014 | 10:00 AM
203006481's Avatar
Default Rocker Arms.
I have a 2002 Chrysler Concorde with the 3.5 Engine.When you first start the motor it has a tapping noise on top for a few seconds like a lifter bleeding off.It stops after a few seconds.Will this hurt the motor until I can come up with the funds to repair.Has anybody replaced both rocker arm assemblies,and did this help your problem.Replacing both rocker arm assemblies is 500.00 plus just for parts not including gaskets and labor.Thanks for any replies,Just trying to spend my dollars wisely.
Old Feb 27, 2014 | 11:22 AM
FIREM's Avatar
Many 3.5's from that era do that. A TSB was issued to fix the problem. Many have run for a long time as long as the noise goes away after 2-3 seconds should be ok. Both my M's do it (140k/160k) usually most noticable when due for oil change.
TSB NUMBER: 09-002-04 SUBJECT:
Short Duration Cold Engine Start-up Ticking Like Sound
OVERVIEW:
This bulletin involves replacing the swivel pads and swivel pad retainer on the exhaust rocker arms.
jimmy154
Nov 3, 2011 07:13 AM
candu30
Jun 26, 2011 10:03 AM
gn300
Jun 17, 2011 07:53 PM
jtrent
Mar 5, 2008 12:07 AM
djones466
Feb 19, 2008 04:39 PM
