Washer pump replacement
Old Aug 18, 2007 | 03:03 PM
98concorde's Avatar
Default Washer pump replacement
Hi, first time asking a question.
Have 98 Concorde LXI and the Washer pump is not working. Need to replace but cannot find any info in my Chiltons repair manual on how to or where it is located? I am asuming that it is located on the Washer bottle, however the bottle it burried beneath a lot of stuff I would rather not take off. Any info very much appricieated.
TIA
98Concorde
[align=left] [/align]
Old Aug 18, 2007 | 06:25 PM
Default RE: Washer pump replacement
WASHER RESERVOIR PUMP REMOVAL[*]Open hood and disconnect the negative battery cable remote terminal from the remote battery post Negative Battery Cable Remote Terminal[*]Hoist vehicle.[*]Remove front fascia as necessary (left side only and use a 2x4 to prop left edge of fascia away from body) Refer to Body for Removal and Installation procedures.[*]Disconnect the wire connectors from the reservoir pump.[*]Gently pry pump away from reservoir and out of grommet. Care must be taken not to puncture reservoir Washer Reservoir[*]Remove rubber grommet from reservoir and throw away. [/ol] INSTALLATION For installation, reverse the above procedures. Use new rubber grommet with new pump. Assure pump is fully seated into reservoir.
Old Aug 19, 2007 | 11:26 AM
98concorde's Avatar
Thanks Chrysler Tech,
Does that mean I don't have to take off the left headlight assembly prior to pulling the facia?
98Concorde
Old Aug 19, 2007 | 06:51 PM
sorry forgot about the fascia part.
FRONT BUMPER FASCIA CONCORE REMOVE[*]Release hood latch and open hood.[*]Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners Access Rubber Grommet[*]Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield Fastener Locations[*]Remove the fasteners attaching the fascia to the upper radiator closure panel Remove Push In Fasteners[*]Disconnect wire connectors (fog lamps, parking/turn signal, side marker), if equipped.[*]Remove fascia from vehicle.[/ol] INSTALLATION[*]Connect wire connectors.[*]Place fascia in position on vehicle, by fitting foam to bumper beam. Use care not to scratch fender. Tape may be put on fender for protection.[*]Install the top center fasteners, to upper radiator closure panel.[*]Install fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield[*]Align fascia to bumper reinforcement.[*]Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender fasteners. Push fascia rearward to engage the fasteners.[*]Install nut on fascia stud through the splash shield access hole, on each side. [/ol]
06RedPacifica
Jul 5, 2016 09:48 PM
eamartens
Jan 3, 2013 06:39 AM
shaunneff
Jul 7, 2011 10:58 PM
sapper7697
Jan 27, 2010 03:15 PM
LT102
Dec 29, 2006 02:52 PM
