Rear Washer Pump Location - 2001 T&C
Old Dec 29, 2006 | 12:54 PM
LT102's Avatar
Default Rear Washer Pump Location - 2001 T&C
My Haynes book doesn't show it and I need to locate the pump for the rear window washer 2001 T&C.
Old Dec 29, 2006 | 01:47 PM
Default RE: Rear Washer Pump Location - 2001 T&C
only one pump for front and rear its on the washer jug. uses a 2 way valve to direct flow of fluid
Old Dec 29, 2006 | 01:53 PM
LT102's Avatar
The front washer works, is there some sort of test I can do to see if the pump needs replaced or if it's something else?
Old Dec 29, 2006 | 02:03 PM
LT102's Avatar
It looks like the fluid tank is down under the fender, is that correct?
Old Dec 29, 2006 | 02:52 PM
yes and yes if u have 2 people there get under the driver side fender and have some one use the rear washer. if u hear it work then its not the motor. U could have something along the line of broken lines or cloged sprayer or valve stuck.
06RedPacifica
Jul 5, 2016 09:48 PM
Darth Menace
Feb 19, 2016 09:16 PM
3.3lxbluevan
9
Dec 10, 2010 07:17 PM
sapper7697
Jan 27, 2010 03:15 PM
98concorde
Aug 19, 2007 06:51 PM
