01 SEBRING HEADLIGHT BULB CHANGE!!!!
This is probably the easiest kind of maintenance but I can't seem to get the headlight assembly out of the car!!!!! ITS NUTS!! I only noticed 2 bolts small one's I think 8 mm and I took them out and it was realy loose but it would not come out. I can't get my hand behind it to just take it out. Its the driver's side so there is the air filter that sets there. Please help. I hate having a padido!!!!!!! (spelling)
THANKS
THANKS
not sure if this will help but this is what it says to do
Disconnect and isolate the battery negative cable.
Remove the two retaining screws.
Remove upper fascia retainers by prying under the head of the fasteners with a flat bladed tool.
Remove headlamp unit from fender side first, then pull headlamp unit out (Headlamp Unit).
Disconnect the wiring harness from the bulbs.
Remove the headlamp unit.
looks like you just about had it out
yeah dcx is not nice on changing bulbs it seems
AdamsLxi
Aug 16, 2012 03:13 PM
bkmatthew
Aug 8, 2011 12:43 PM
bargainstyle
Jun 27, 2011 09:04 AM
