01 trans won't shift
Old Jun 16, 2010 | 07:15 PM
dblcruzin's Avatar
Default 01 trans won't shift
It seem like it would not work right when it was cold now it seems like it goes direct into 2nd gear then it stays there some times it will shift like new and then the next time driven it won't shift right again rev work's fine will spin tires in rev any thoughts?
Old Jun 17, 2010 | 07:01 PM
What have you checked? Fluid, leaks, pressure test, codes?
There are many ways to diagnose tranmission problems. You'll need to avail yourself of them.
Old Jun 18, 2010 | 06:20 AM
dblcruzin's Avatar
ran codes last nite p0700?
Old Jun 18, 2010 | 04:35 PM
That's just a general code telling you that there are problems with the transmission that can be read with a code reader that is capable of going deeper than the usual OBD 2 scanner. You're going to have to have some higher level equipment scan your codes.
Have you at least checked the fluid?
Old Jun 23, 2010 | 09:46 PM
dblcruzin's Avatar
sorry took so long yes have checked fluid shifted fine for two days then back to limpin mode what other kind of code reader is needed?
Old Jun 24, 2010 | 10:13 PM
Drb iii.
mta318
Sep 25, 2012 04:47 PM
OV10dude
Cirrus & Breeze
Jul 23, 2012 04:36 PM
laura
Apr 11, 2010 08:48 PM
jhuntsebring
Mar 1, 2009 10:33 PM
benr
Feb 25, 2007 03:44 PM
