02 Sebring rack reseal
Old Oct 1, 2018 | 12:56 AM
Bythepond88's Avatar
Default 02 Sebring rack reseal
My steering has been locking up when first starting up the car off and on for a few months. At first, I only experienced it when backing out of my parking space when leaving home or work. But lately, it has started acting up a few times even after getting out of the parking lot. I'm guessing that the rack is the culprit, but am not sure, I replaced the belts a month ago, so that should not be the problem. My questions are:
1. Am I correct that the rack is the likely culprit?
2. Is it worth trying to rebuild the rack"
3. In looking at prices on replacement racks, I've seen "firm feel steering" as an "option. How do I know if that's what I have?
Thank you for any replies.
Old Oct 1, 2018 | 09:46 AM
Have you checked the fluid? If it's low or old you might get a symptom like that. If it's never been replaced it would be worth the effort to do so before spending a lot of money replacing the rack.
Old Oct 1, 2018 | 10:50 AM
Thank you, Dcotter. Fluid is full, but I will try replacing it.
Old Oct 7, 2018 | 11:58 AM
I checked the fluid and it is very clean. Do you still suggest I do a flush ad fill?
Old Oct 7, 2018 | 06:43 PM
If it works and saves replacing the rack, it would be money well spent. No guarantee that it will solve the problem though. It's your call.
Old Oct 8, 2018 | 12:25 AM
What fluid should I use? I seem to recall reading that Chrysler at one point saying not to use ATF, but also reading that Chrysler had issued a TSB that changed the spec to ATF+4. FWIW, the fluid currently in the P/S reservoir is a clear red. Thank you for all your help and input
Old Jan 6, 2019 | 08:46 AM
nauman_mustafa's Avatar
I am worried for Power steering rack and rust issue! As till i couldn't solved problem yet. Don't know what should be do for a permanent solution?
paakraat
Jan 26, 2019 02:07 PM
Bythepond88
Nov 26, 2018 01:19 AM
keithm
Dec 31, 2012 02:01 PM
ettienne
Dec 14, 2010 07:33 AM
Pacifica3.82007
Mar 14, 2009 10:48 PM
