03 Sebring Sedan power windows not working
2003 Sebring Sedan, the power windows on the driver's side did not work, I unplugged the window switch and all the switches checked out good for the left side up and down. I checked all the fuses and the CB for the power windows, slot 19, 30 amp all ok. The right front window motor reads 2.2 ohms. I have a good ground on pin 10 or the power window switch but no power at the switch. Now none of the windows work.
Am I missing something? |
There's probably a broken wire in the harness leading to the door. Flexing that harness as the door opens and closes results in broken wires. People have reported that issue here.
Could I just jumper the hot wire from the door lock to the window connector? Do you know which pin is the hot wire?
Pin 1 should be getting power from the ignition key. Not a good idea to power the windows from the locks. Locks are controlled through the body computer.
