03 Sebring Sedan power windows not working
Old Mar 9, 2018 | 11:06 PM
turnerma's Avatar
Default 03 Sebring Sedan power windows not working
2003 Sebring Sedan, the power windows on the driver's side did not work, I unplugged the window switch and all the switches checked out good for the left side up and down. I checked all the fuses and the CB for the power windows, slot 19, 30 amp all ok. The right front window motor reads 2.2 ohms. I have a good ground on pin 10 or the power window switch but no power at the switch. Now none of the windows work.
Am I missing something?
Old Mar 10, 2018 | 09:24 AM
There's probably a broken wire in the harness leading to the door. Flexing that harness as the door opens and closes results in broken wires. People have reported that issue here.
Old Mar 10, 2018 | 10:53 AM
turnerma's Avatar
Could I just jumper the hot wire from the door lock to the window connector? Do you know which pin is the hot wire?
Old Mar 10, 2018 | 01:02 PM
Pin 1 should be getting power from the ignition key. Not a good idea to power the windows from the locks. Locks are controlled through the body computer.
Princessmobile
Other
Jul 19, 2017 11:09 PM
chipy66
Jun 13, 2013 05:30 PM
Frosty68
May 6, 2013 08:44 PM
braddm
Dec 24, 2007 05:03 PM
