04 sebring coupe limited rear hubs?
I have a 04 sebring coupe limited, NON ABS, 4 wheel disc brake that needs rear hubs or bearings. I CANNOT find a rear hub assembly for this,...every one has a ABS ring or just does not look like mine. After removing the back 4 knuckle mounting bolts i noticed a large nut on the back side similar to the type on car front ends where you replace the BEARINGS,..not the whole hub assembly. Is this true? THAT,...would explain WHY i cannot find a whole hub.
When ordering parts for your car be very sure that you specify that it is a coupe. The Sebring coupes were built by Mitsubishi, not by Chrysler. The comparable Mitsu model is the Eclipse. Parts such as what you are looking for that would fit the Mitsubishi model will almost certainly fit the comparable Sebring. Parts that fit a Sebring sedan or convertible will not fit your coupe.
Scotsman4th
Aug 8, 2013 02:34 PM
ecfilms123
Mar 25, 2011 10:53 AM
