04 Sebring Oil Pan replacement cost?
Old Mar 5, 2012 | 05:31 PM
JimboXL's Avatar
Default 04 Sebring Oil Pan replacement cost?
I was informed at my last oil change that my pan is screwed so to speak. Something related to the screw threads. Anyways Ill have to get another from Chrysler, anyone have any idea how much these cost?
Old Mar 5, 2012 | 07:20 PM
teddysmith1952's Avatar
Hummm. Something doesn't sound right. The oil pan only has round holes and the threads are located on the engine block. Are you sure the Tech wasn't talking about a bad (leaking) oil pan gasket?
Old Mar 5, 2012 | 07:29 PM
TNtech's Avatar
The oil pan is aluminum and threads getting stripped is all too common. Caused by a ding-a-ling doing an oil change and not knowing how tight a drain plug should be...or should I say...NOT be. Call the dealer and ask how much it is.
Old Mar 5, 2012 | 07:36 PM
Sorry about my previous comment. The Oil "drain plug"....of course. I was thinking the oil pan bolts was the issue..
Old Mar 5, 2012 | 07:40 PM
TNtech's Avatar
Hehe, if I had nickel for every one of those i've seen stripped
Old Mar 5, 2012 | 08:10 PM
JimboXL's Avatar
I've been going to the same place for oil changes for at least 6 yrs on this car. I get the oil changed prob every 3000 which means in a regular year I've probably had it changed around 5 or 6 times. Do you think wear and tear after years of oil changes plays any role given that other parts on the Sebring simply break or crack ie resonator and rear strut mounts?
Old Mar 5, 2012 | 08:30 PM
no u can only tear up a bolt hole if U put it in wrong a few times
Old Mar 5, 2012 | 10:06 PM
If you have always gone to the same place for your oil changes, then there's the ding-a-ling right there who buggered up the threads on the oil pan. Personally, I'd say he owes you a new oil pan-installed.
Old Mar 5, 2012 | 10:38 PM
JimboXL's Avatar
I don't see that short of bringing a certified Chrysler technician with me to testify that I'd get them to pay for my oil pan. Does that happen ever at any shop unless they do something obvious like blow your engine after a bad oil change?
Old Mar 6, 2012 | 09:03 AM
You probably don't need a Chrysler certified tech to be your expert witness. Anybody who has changed oil for a living ought to be able to testify as to the right way to do it and the consequences of doing it wrong.
Once you have pulled the old pan off, take it back to the oil-change place and show them the damage they did. Their own records will confim that it was their work. I would suspect that they might be happy to pay for the new part to avoid having to spend a day in small claims court.
If yours is a V-6, there's a photo album on the forum here showing how to remove the Y-pipe which you will need to to to get the oil pan off.
virgil
Feb 20, 2011 08:15 PM
I wonder
Mar 1, 2008 08:35 AM
02sebringCT
Nov 22, 2007 12:39 PM
catliketheif6
Nov 20, 2007 11:27 PM
dennine3003
Feb 24, 2006 07:50 AM
