07 sebring cranks wont start....
Old Sep 1, 2008 | 04:19 PM
ROb B's Avatar
Default 07 sebring cranks wont start....
I have an 07 sebring, it stalled while driving several times, and it started back up, when I got it home, I perked in the driveway, and now it will not start, although it starts every now and then only to quickly shut down. Anyone else have the same or similar probs????
Old Sep 1, 2008 | 08:38 PM
Default RE: 07 sebring cranks wont start....
If it's an 07, it's still under warranty, isn't it? If so, tow it to the dealer and get it fixed. At the very least, check for codes via the OBDII plug. With this sort of behavior, something is bound to show up. There's little point in speculating.
Old Sep 5, 2008 | 12:50 PM
dodgeman213's Avatar
i agree with the above poster. no reason why an 07 should be giving you problems just yet.
auto insurance
Old Sep 6, 2008 | 05:07 PM
Attitude0917's Avatar
Have you tried your spare key? One of my keys on my 02 messes up every now and then, security thinks its being stolen... shuts it down. Could be a bad key.
Old Sep 7, 2008 | 09:31 PM
bandaide's Avatar
The other question about keys is, have you recently purchased a new key and are you using it when you're having problems with the car? If you have the old one that came with the car, try it and see how it behaves.
Old Sep 8, 2008 | 09:18 AM
Another problem that can happen with keys is that if you have something else on the key ring that interferes with the security key, you might be getting a cross-signal that confuses your security system. Try taking the car key off the ring and using it all by itself with the other keys kept well away. It's a cheap and easy test.
Old Sep 8, 2008 | 08:16 PM
irdaneel's Avatar
My 97 had an ASD relay problem that mimicked exactly what you are saying. My problem was specifically in the connector to the ASD relay. Fixed that, and no more stalls or no starts.
But! if it is an 07, make the dealer handle it under warranty.
Onyxman
Feb 27, 2014 01:51 PM
Jacob Ullman
Apr 15, 2012 07:49 PM
chengthao85
Jun 11, 2011 03:08 PM
size2020
Oct 17, 2009 08:21 PM
jonboy_4x
Apr 6, 2008 12:19 AM
