1997 sebring 2.5 misfire #4
Old Aug 9, 2009 | 08:05 AM
dappleco's Avatar
Question 1997 sebring 2.5 misfire #4
HELP!
1997 Sebring 2.5 Convertible with a misfire on cyl #4.
Vehicle is running rough and would shut off. Restart car would run for a moment or two then shut off. Replace an *** load of parts, distributor, injectors, multiple sensors, magnets all kids of replacement parts.
The car now will stay running but is extremely rough. OB2 list error code as misfire on #4 cyl
On top of the rough running the car will stall out and shut down if the fuel goes below ½ of a tank?
HELP?
What can I do here??
john
Old Aug 9, 2009 | 02:40 PM
Ram's Avatar
Ram
First thing that comes two mine when reading your post: and not knowing what load of parts were exactly change when conditions did improve.
I would hope that these parts were possibly changed:
- air filter
- spark plugs, and gaped correctly
- plug wires, adhering to firing order
- distributor cap
- distributor rotor
- fuel filter
- checked fuel pump pressure
- cylinder compression test
- cylinder leak down test
This is where I would check if not replaced.
You don't mention any burning of oil, is it?
It almost sounds like you may have water in the fuel as well?
Old Aug 9, 2009 | 07:46 PM
Yeah, double check to make sure you haven't mixed up spark plug wires. Then check your fuel pressure. A bad load of fuel could have clogged your filter and/or injectors.
Old Aug 10, 2009 | 05:23 AM
dappleco's Avatar
Done and done again!
Well the only thing left to do is a comp test
thanks
Old Aug 13, 2009 | 05:37 PM
Ram's Avatar
Ram
What brand plugs are you using?
rComplex
Dec 21, 2014 01:01 PM
Sguimet
Oct 28, 2011 08:24 PM
l.g0883
Oct 24, 2011 12:56 PM
Johnny_Sebring
May 13, 2011 07:21 AM
cfreed
May 6, 2011 06:20 AM
