1997 Sebring Convertible transmission computer
Here is the solution to your problem:
Chrysler automatic transmission repair: solenoid pack rebuilding
and once again THAT SOUND IS NORMAL EVERY 41TE transmission sounds is normal
Fare warring that repair u will do at your own risk not advisable.
A couple of observations here. I've owned two Sebrings with 41TE transmissions and never noticed any noise like that.
As for the article, the guy bought a kit and rebuilt his solenoid pack. It's a lot easier and not much more expensive to just replace the solenoid pack as an assembly. He makes a good point about cleanliness in the process.
The guy in the article replaced the ATF +3 transmission fluid with ATF +4 fluid. That may not be such a great idea. If the transmission was designed around ATF +3 fluid then that's what you should use.
97jxi
Nov 9, 2008 08:29 PM
ernie
Sep 20, 2007 01:22 PM
sumncguy
Jul 13, 2007 11:33 AM
