1997 Speedometer, odometer intermittant
I bought a 1997 sebring convertable and when first firing up the ride and after somelengthy travel, the speedometer doest work and the lighted odometer isn't showning. The tach works as well as everything else. After awhile, perhaps after a bump or two, it starts to work. The odometer is wracking up the miles which is fine. Is there a TSB about some connectors or do I need to replace the cluster? Thanks.
RE: 1997 Speedometer, odometer intermittant
hey bud, you might want to check on a loose connector behind the cluster itself.see if you can narrow it down by moving the harness behind the cluster,hers what your dealing with.good luck.moehttps://w05.dealerconnect.chrysler.c...S/jx780253.gif
INSTRUMENT CLUSTER- C2 CAV CIRCUIT FUNCTION 1 L39 18LB FOG LAMP SIWTCH OUTPUT 10 E2 18OR/YL PANEL LAMPS DRIVER GROUND 11 Z1 18BK/OR GROUND 12 G6 20GY OIL PRESSURE SWITCH SENSE 13 G19 20LG/OR ABS WARNING LAMP DRIVER 2 L61 18LG/TN LEFT TURN SIGNAL 3 D2 20WT/BK (WITH TRAVELER) TRAVELER CCD BUS (-) 4 D1 20VT (WITH TRAVELER) TRAVELER CCD BUS (+) 5 F18 20LG/BK FUSED IGNITION SIWTCH OUTPUT (RUN/START) 6 G9 22GY/DB RED BRAKE WARNING LAMP DRIVER 7 D2 20WT/DB CCD BUS (-) 8 D1 20VT/BR CCD BUS (+) 9 - -https://w05.dealerconnect.chrysler.c...S/jx780252.gif INSTRUMENT CLUSTER -C1 CAV CIRCUIT FUNCTION 1 L60 18TN/BR RIGHT TURN SIGNAL 10 - - 11 - - 12 - - 13 G78 20TN/BK TRUNK AJAR SWITCH SENSE 2 F11 18RD/VT FUSED IGNITION SWITCH OUPTU (OFF/RUN/START) 3 - - 4 Z2 18BK/LG GROUND 5 F33 20PK/RD FUSED B(+) 6 - - 7 G69 20BK/OR (WITH VTSS) VTSS INDICATOR LAMP DRIVER 8 G29 20BK/TN WASHER FLUID SWITCH SENSE 9 - - |
thanx for the info.
cool!
printed circuit board in the cluster is bad.
If you play with it long enough, and have the patience and proper electronic tools, you may find a cold solder joint in the PC board, or wiring connectors.
You might want to check here, they fixed my "indglo" that the dealer said would be $1200 for a new dash.
http://www.mrwhizard.com/services2.cfm#Start Mike |
