2.7 Engine swap: Stratus to Sebring… is it direct swap?
Old Oct 29, 2007 | 08:52 AM
andbudzi's Avatar
Default 2.7 Engine swap: Stratus to Sebring… is it direct swap?
I have 01 Sebring with 2.7 engine, and need to put in new engine due to engine failure.
Does anyone know if 2.7L engine from 04 Dodge stratus is direct swap?Also wondering if I can disconnect engine from trany and pull it our through the front (taking radiator and radiator support of)?
Old Oct 29, 2007 | 10:18 PM
master tech's Avatar
Default RE: 2.7 Engine swap: Stratus to Sebring… is it direct swap?
The engine are the same, but the 2001 as a active intake manifold. That is the only it shows with a active manifold. So if you use the motor switch the intake manifold on new motor. Also clean the intake out, there maybe pieces of the old motor in it.
Old Oct 29, 2007 | 11:24 PM
andbudzi's Avatar
thank you....i bought the engine from stratus and have second thought after reading that intrepid 2.7 have a bit diferent trany hook up..... hopefully it will come out throught the front with radiator out
Old Nov 29, 2007 | 08:39 PM
01SebringLx's Avatar
Honestly dude, i would not recommend getting a 2.7L engine at all. I would try and upgrade to the 3.0L engine because the 2.7L ALWAYS has problems, I have the 3.0L and it runs perfectly fine
Old Feb 1, 2008 | 09:56 PM
Zdaddy's Avatar
Sorry to revive an old thread, but does the 3.0L bolt up to the 2001 Sebring (2.7L) with the crossmember+mounts etc???
I know nothing about these motors, I'm a nissan kinda guy, so sorry for the ignorance.
Anyone have a writeup with pics etc... of everything I need.
I'm imagining this wont be a direct fit and will need custom motor mounts,
Tranny? I have no idea of the tranny if it will bolt up or what
Harness+ECU? Probably harness and ECU for the 3.0L ?
Anything else?
I'm looking for direct bolt on swap options. I don't mind doing a little bit of harness+ecu customization...but tranny and motor mounts... I really don't want to even touch with a 10 foot pole. [:'(]
Old Feb 2, 2008 | 08:04 PM
powers84's Avatar
doesnt the 2004 engine have a different computer then the 2001 does , refering to the 2.7
Old Feb 3, 2008 | 08:32 AM
yes Sbec to a NGC connectors and setup different.
Old Feb 3, 2008 | 08:39 AM
powers84's Avatar
canyou just can the engine harness and computer and have it work
Old Feb 3, 2008 | 07:03 PM
your still messing with something that U dont know about have a chrysler guy take a look at it for u.
Old Feb 9, 2008 | 08:00 AM
powers84's Avatar
i went down to the chrysler shop and the guy told me that it was illegal and a bunch of other bull**** answers the guy was a dick. he didnt know anything
