2001 Sebring LE instrument panel problem
Old May 25, 2008 | 04:25 PM
anabel99's Avatar
Default 2001 Sebring LE instrument panel problem
Hi, I´ve a Sebring LE 2001, this week when I start on my car I´ve problem whit somes indicators in instruments panel.
When I turn on the instruments that measuring fuel, temperature and speed goes to the middle scale.
I check that the car have the tank fuel fully, and the temperature is cold and no move the car.
I check the car in a official dealer service and tell my that the car work´s OK!!!.
I hope that anybody have some similar problems.
Any suggestions are welcome
Thanks in regard.
Old May 26, 2008 | 09:13 PM
irdaneel's Avatar
Default RE: 2001 Sebring LE instrument panel problem
My 99 Sebring guages are very sluggish, but within about 3 minutes have settled in. (Especially after refueling) If they are continuously reading in the same position then there is a problem. It is likely in the cluster of guages, or perhaps the entire thing. It could also be in the connections at the back of the cluster.
Check ALL of you fuses both inside and under the hood. Wiggle some wires and connectors around under the dash and under the hood (Gently!) to see if you get any response. If not, you'll probably need a new instrument cluster.
Brian0514
Dec 7, 2010 10:34 AM
71grande
May 23, 2010 08:55 PM
Josho
Nov 25, 2008 01:24 AM
TheCoutures
Sep 17, 2008 09:04 AM
sistegraf
Dec 21, 2007 05:23 PM
