2002 Sebring LXI AC Problem
Problem: Ac turns on when it wants to, not when we want it to.
So the ac comes on as soon as the compressor turns on. It blows cold. But like i said it comes on when it wants to.
Low side 35
high side 150 both at about 70 degrees outside.
I charged it up with another can, nothing has changed.
Kind of stuck. Thanks
Thomas
Low side 35
Thomas
ok first of all if your gauges are pre 134 then they wont hook up r12 and 134 use different size connectors and u should have about 100 psi on both sides when the compressor is not on and when running about 35 to 250.
when it wont work check for the power and ground at the compressor connector see which u are missing.
actionkid7007
Oct 18, 2010 02:57 PM
muffinman14
Jan 10, 2008 05:50 PM
