2002 sebring sedan 2.7
The speedometer don't work, I need the wiring diagram, thanks.
It's a lot more complicated than that. The speedometer operates from data communicated to it over the data bus from the body computer, which in turn receives data from the transmission computer reading the output speed sensor.
Are your cruise control and odometer working correctly? If so, the problem is most likely in the instrument cluster. If not, the problem is probably farther upstream. |
Speedometer
(Post 39285)
I think that you can check in the net about the wiring diagram.I am sure you'll get.
The instrument cluster is replaced as a unit. Search the internet for sources. There are people who specialize in that.
