2002 sebring sedan 2.7
Old Aug 1, 2010 | 11:12 AM
gonzalocimma's Avatar
Default 2002 sebring sedan 2.7
The speedometer don't work, I need the wiring diagram, thanks.
Old Aug 1, 2010 | 07:45 PM
It's a lot more complicated than that. The speedometer operates from data communicated to it over the data bus from the body computer, which in turn receives data from the transmission computer reading the output speed sensor.
Are your cruise control and odometer working correctly? If so, the problem is most likely in the instrument cluster. If not, the problem is probably farther upstream.
Old Aug 5, 2010 | 10:58 PM
Default Speedometer
Hi, the odometer work good, I can replace only the speedometer or I need replace all, thanks.
Old Aug 6, 2010 | 03:35 AM
smith46's Avatar
I think that you can check in the net about the wiring diagram.I am sure you'll get.
Old Aug 6, 2010 | 09:35 AM
The instrument cluster is replaced as a unit. Search the internet for sources. There are people who specialize in that.
zingerlicious
Jul 17, 2011 07:58 PM
Jen8112
Oct 14, 2010 08:26 AM
cadwallender
Aug 12, 2009 01:36 PM
zingerlicious
Nov 22, 2008 01:56 AM
