2003 Chrysler Sebring Keyless Entry Remote Programming Help
Hi, we Just purchased a 2003 Chrysler Sebring convertible but the car did not come with any remotes I did call some Chrysler dealers they want $75 to program are new remotes. I did find some instruction online that said you can take a wire or paper clip and running it from pin 1 to pin 4 to do the programming would this work for my car I just want to make sure any Help would be appreciated
U will need to go to the dealer to program remotes the only way a cust can program there own is if U have 2 working remotes already and don't put any paper clip into any electrical socket with out knowing what is on that circuit
Totally agree with CHRYSLER TECH. I purchased a 2002 Sebring LXI this last November which had no remote entry included. I bought two used remotes from a reputable Ebay seller for like $25 for both. My local dealer programmed them for $29.00. It took the guy about 5 minutes.
Thanks for the help here is the programming instructions I found online is this for a different year?
Here is a quick HowTo on programming your own keyless entry:
1) Turn ignition to OFF.
2) Locate the Data Link Connector, its a black 16 pin connecter that is under the driver's side dash, right where your right knee would be. You have to look up into the dash from below to see it.
3) Ground pin 1 of the Data Link Connector by taking a wire or paper clip and running it from pin 1 to pin 4. Pin 4 is ground so you can just short pin 1 to 4 and it will be grounded. Grounding pin 1 tells the system you are ready to reprogram it.
4) Close all of your doors.
5) Turn the key to ACC then back off. The power door locks will lock/unlock. This is the signal that the system is ready for reprogramming.
6) Push a button on your key fob, doesn't matter which button.
7) If you have 2 key fobs, then press a button on the 2nd fob within 1 minute of pressing a button on the 1st fob. Both must be programmed at the same time. If you only have 1 fob then press a button 2 more times to signal that you only have one.
8.) The doors will lock/unlock to signal the codes were received.
9) Remove the jumper wire from the data connector.
why want my Chrysler Sebring limited convertible 2002 crank or start over for me. I changed the engine and the ECM an it crank for a couple seconds about 3 times then it jus wouldn't say a thing security lights want go out anybody got any ideas what's up with it.
Casper_1984
Jun 8, 2011 12:45 PM
lerouxmarais
Jul 5, 2009 09:47 PM
96SebringJxi
Oct 28, 2007 11:26 AM
