2003 Sebring Spark Plugs for 2.7L V6
Old Jul 22, 2015 | 01:39 AM
bocajoe's Avatar
Default 2003 Sebring Spark Plugs for 2.7L V6
Hi there. I'm looking for recommendations on spark plugs for my 2003 Sebring 2.7L V6. What plugs came factory and/or what plugs are preferred on a stock motor?
Old Jul 22, 2015 | 08:25 AM
champion platinum factory
Old Jul 22, 2015 | 08:28 AM
bocajoe's Avatar
Excellent... thank you very much CHRYSLER TECH!
Old Jun 3, 2018 | 04:14 PM
gpatel's Avatar
Default 2006 sebring 2.7 water leak, top left side of engine.help?
Hi my car is leaking water on left side of engine. I want to take that big black plastic thing off the engin but dont know what size bolts they are. Ate they metric or imperial, and what is the size please? There are about 5 maybe 6 bolts holding this thing down. I dont know what the leak is, but its set by the left side plastic thing with water air bleed valve on top. I am windering if it is cracked.
any suggestions welcome, but i need to know bolt size to buy tool. Is this a special deep socket or something, because i tried so many sockets and nothing fit.
there is no water in the engine oil. So what else can this leak be from?
thank you
gpatel
Old Jun 3, 2018 | 04:41 PM
The thing on top of the engine with the bleed screw is called the coolant outlet manifold. There are many entries here on the forum about it and how to remove it and what tool is required. (8mm flex head). When you say it's on the "left side of the engine" are you referring to where it is as you look at it from the front of the car? If so, that's the wrong way to describe it.
Old Jun 5, 2018 | 08:09 AM
gpatel's Avatar
Thanks dcotter0579, you reply above really helps me to now describe it correctly. Very Helpfull and informative!
keygar
Jan 31, 2019 04:18 AM
Jose Vega
Aug 17, 2018 04:43 AM
gpatel
Jun 3, 2018 03:19 PM
queengsc
Apr 17, 2012 03:26 PM
dbooth
Sep 19, 2010 09:18 PM
