2004 Seabring Conv 2.7
Old Mar 29, 2011 | 03:25 PM
estein01's Avatar
Default 2004 Seabring Conv 2.7
Does anyone know how I can verify the engine serial number to the VIN?
Here is the situation;
The engine oil pressure light would come on at idle and after the engine had fully warmed up. I would occasionally check oil level and top off as needed. I figured it was the oil pressure switch going bad as well as a small leak.
About 6 months ago while driving home, the car just died. I had it towed to a shop and they looked at it and discovered that the engine had seized. Paid $5500 to have a rebuilt one put in.
Almost immediately after the new engine was put in I started getting the same light coming on as it did with the old engine.
I would think that a rebuilt engine would include an engine oil pressure switch so it shouldn't be, presumably, the same one that was in the old engine.
I am starting to wonder if the shop actually changed the engine out. I got a pretty iffy feeling about them when I was there.
Comment and questions are welcome and helpful.
Eric
Old Mar 29, 2011 | 06:07 PM
doeboy's Avatar
man you should of made a mark on the engine to figure that out. Why even bother having it repaired for that amount by a shop you feel anything less than certain about? For that kind of price you probably could of had a dealer do it.
Old Mar 29, 2011 | 06:12 PM
if it runs it runs they either put a new one in or rebuilt it either way it runs better then it did also take it back to them if U have issues with it they have a warranty
Old Mar 29, 2011 | 07:13 PM
estein01's Avatar
I had it towed at 10p.m. and I was on a plane at 7 a.m. the next morning so I didn't have time to mark it or anything and I was gone for 2 weeks while it was being worked on. I didn't actually go into the shop until the work was done. I relied on a friends recommendation as to which shop to take it to.
I still want to know if there is a way to compare engine serial number to VIN if anyone knows.
Eric
Old Mar 29, 2011 | 09:47 PM
no it does not work like that if its a used engine a mechanic will know there will be signs
samanthahotmess
Jun 9, 2014 02:26 PM
aifam55
Jan 22, 2011 05:49 PM
jasonu76
Apr 20, 2010 02:10 PM
seabringwannabe
May 30, 2006 11:55 PM
