2004 sebring 2.7 code "p0688" help please
Old Apr 22, 2021 | 10:55 PM
flamaui's Avatar
Default 2004 sebring 2.7 code "p0688" help please
Finally got this code doing ON and OF 3 times on the key ignition.
Changed the battery, crankshaft position sensor and spark plugs.
Still crank and no start.
Any help will be appreciated.
Old Apr 23, 2021 | 09:51 AM
Old Apr 23, 2021 | 07:10 PM
flamaui's Avatar
Thank You!
Old Apr 24, 2021 | 02:55 AM
flamaui's Avatar
RESOLVED, yes finally got fixed. It took me 15 minutes cleaning the ASD relays. I have no idea how all that dirty got inside. all 3 relays needed to be cleaned . I didn't have to spend money buying a new one
I really appreciated from everyone special dcotter0579.
Old May 8, 2021 | 09:26 AM
toyota's Avatar
Hi, Please can you tell me what the ASD relays look like an dhow to locate it?
I would like to clean mine but dont know what it looks like and how to clean it.
Can you add a photo?
Thank you
I have a 2006 Sebring Touring 6 cylinder
Old May 8, 2021 | 09:27 AM
toyota's Avatar
Question
Thank you
Old May 8, 2021 | 09:34 AM
The following text is from the factory service manual: (The PDC is the fusebox under the hood)
AUTO SHUT DOWN RELAY
DESCRIPTION
The relay is located in the Power Distribution Center
(PDC). For the location of the relay within the
PDC, refer to the PDC cover for location. Check electrical
terminals for corrosion and repair as necessary
OPERATION
The ASD sense circuit informs the PCM when the
ASD relay energizes. A 12 volt signal at this input
indicates to the PCM that the ASD has been activated.
This input is used only to sense that the ASD
relay is energized.
When energized, the ASD relay supplies battery
voltage to the fuel injectors, ignition coils and the
heating element in each oxygen sensor.
When energized, the ASD relay provides power to
operate the injectors, ignition coil, generator field, O2
sensor heaters (both upstream and downstream),
(EGR solenoid and PCV heater if equipped) and also
provides a sense circuit to the PCM for diagnostic
purposes. If the PCM does not receive 12 volts from
this input after grounding the ASD relay, it sets a
Diagnostic Trouble Code (DTC). The PCM energizes
the ASD any time there is a Crankshaft Position sensor
signal that exceeds a predetermined value. The
ASD relay can also be energized after the engine has
been turned off to perform an O2 sensor heater test,
if vehicle is equipped with OBD II diagnostics.
As mentioned earlier, the PCM energizes the ASD
relay during an O2 sensor heater test. This test is
performed only after the engine has been shut off.
The PCM still operates internally to perform several
checks, including monitoring the O2 sensor heaters.
Old May 8, 2021 | 12:42 PM
toyota's Avatar
Default Thank you
That was a great write up,
Thank you
Old May 8, 2021 | 03:13 PM
flamaui's Avatar
It looks like this:
Good luck
Old May 8, 2021 | 03:15 PM
flamaui's Avatar
Check this one too:
