2004 Sebring 2.7 Engine coolant leak
Old Feb 9, 2011 | 05:00 PM
z131's Avatar
Default 2004 Sebring 2.7 Engine coolant leak
I have a 2004 Sebring with a 2.7 Engine, Its leaking coolant so bad from two places one close to the right tire and the other place is in between the heads, I got the upper intake out and I Was trying to replace the intake gasket but there was no intake manifold. any idea where that leak is coming from ? there was a pool of coolant between both heads, could it be leaking from the heads ? is that even possible ?
my other question is any one have a repair manual I can use, it will help me big time.
I appreciate and very thankful for any help in advance.
Old Feb 9, 2011 | 05:33 PM
Djinn-n-Tonic's Avatar
Yes, it is possible for it to leak from the heads, but not likely.....
See the black Plastic housing with the bleeder screw on it??? where the upper rad hose attatches???
Look carefully where it meets the motor. Common spot for leakage....Fills the valley, and runs down the front cover...Probably responsible for both leaks.
leave the upper intake off.....it needs to be removed to replace this. (Or at least moved out of the way)
Old Feb 9, 2011 | 05:51 PM
z131's Avatar
I checked it already and its not leaking from the coolant housing or coolant air bleeder. I saw the coolant drip a lot close to the tire where the water pump is located, is it hard do I have to replace the water pump or just the seal ? how hard is it to replace it ? any one can help me with steps ? I asked Midas and they said they will charge me over 600 bucks just for labor. I can do it only if I have the steps
Old Feb 9, 2011 | 06:54 PM
A water pump WILL NOT account for the coolant in the valley.
Look under the car...The weep hole for the pump is just above the A/C compressor.
In all honesty, A water pump on a 2.7 is NOT something you want to tackle in your driveway.
Old Feb 10, 2011 | 09:30 AM
z131's Avatar
Whats the weep hole is for ? Ive done lots of engine work on an OHV engines but never worked on an DOC. Ive done head gasket jobs and and intake. the only think I'm worried about is I might mess up the timing
Old Feb 10, 2011 | 11:05 AM
TNtech's Avatar
To route the leak outside the engine so you can see it. the water pump on a 2.7 is basically in the crankcase. The hole is tight above the t-stat housing.
zaman65
Apr 25, 2013 06:47 AM
BiggRadd
Apr 24, 2012 10:28 PM
besterfe
Jan 16, 2012 10:53 PM
jimG
Sep 8, 2010 12:26 PM
3.3lxbluevan
May 21, 2010 11:20 PM
