2004 Sebring Sedan...Horn Malfunction
Old Apr 19, 2007 | 02:44 AM
crazyjoe86's Avatar
Default 2004 Sebring Sedan...Horn Malfunction
My mother inlaw has a 2004 Sebring Sedan, which when she went to have inspected today, failed, as the horn when depressed by the mechanic wouldn't shut off...So, along with failing it, he somehow disconnected it. Upon, contacting the dealer, them claimed that the horn switch, along with the airbag and some other items would need to be replaced, at the expense of over 1000 dollars....ouch! I checked the fuses, and the mechanic must have unplugged the horn from the actual horn, as the fuses were present, both under the hood, above the battery and inside the drivers door....I drive a 1954 Dodge Coronet...lol....but for the life of me couldn't find the horn on this Sebring, I figured it most be behind the grill somewhere....but no luck....So, my question is, Where is the horn located, do you guys think he just unplugged it from there, and is it possible to fix this problem myself, as I am quite handy with cars....Any help in this matter would be most appreciated...Joe
Old Apr 19, 2007 | 02:55 AM
Default RE: 2004 Sebring Sedan...Horn Malfunction
well i can tell u this if u plug the horn back in the it will just keep going off untill the fuse blows. The horn pad it the cause and 1000 ouch humm find out how much just the part is and u can do it yourslef just unplug the batt because u will be messing with the air bag on the wheel when u get the new pad u will see what it loks like and what to install a new one. The horns are located under the right side headlight assembly take it out and u will see it.
Old Apr 19, 2007 | 03:16 AM
crazyjoe86's Avatar
Thanks alot....that really helps....Do you have any good resources as to where to find the part or even the exact name so I know what to ask for?....Thanks again...Joe
Old Apr 19, 2007 | 03:27 AM
horn pad or airbag cover ,dealer its not a part u can get aftermarket i see retail the part is about 160 bucks that is just the first part number i got it might be a lttle off because there are 15 different ones via color shape and outfit. Have the dealer check it for u call them up parts department.
Old Apr 19, 2007 | 03:39 AM
crazyjoe86's Avatar
Thanks again....Your the Man.....much appreciated
Hooten15
16
Sep 13, 2017 05:37 PM
D-Day
Jul 9, 2012 07:50 PM
exit9sebring
Jun 26, 2007 04:30 PM
exit9sebring
Apr 11, 2007 01:20 PM
