2004 Sebring Timing
Old Sep 27, 2012 | 04:09 PM
carsonabudget's Avatar
Default 2004 Sebring Timing
My 2004 Sebring Convertible 2.7 blew the head gaskets from overheating. The cause of the over heating was a bad PCM that did not tell the fans to come on. One of the heads had a broke cam bearing cap so I replaced the heads with the cams from a 2004 Dodge Stratus 2.7 after I had them remachined. I also replaced the water pump, primary timing chain and tensioners.
After putting it back together I kept getting the codes P0344 (Camshaft Position Sensor A Circuit Intermittant) and P0016. (Crankshaft Position Camshaft Position Coorrelation) I replaced the cam sensor and the crank sensor. Still had the codes. Retimed it several more times and always the same result. Replaced the PCM. Still P0344 and P0016. Any ideas of what else to try would be much appreciated.
Old Sep 27, 2012 | 04:15 PM
I like to add that the car is also in limp mode, not going over 2200 rpm and the engine light is on.
Old Oct 5, 2012 | 12:50 PM
Search the forum here. There has been lots of discussion including pictures posted up. Get the correct manual.
woodss
Jan 10, 2014 02:21 PM
CP35
May 28, 2012 01:53 PM
dixiedemon
Feb 13, 2012 02:37 PM
Clay
Sep 12, 2011 11:13 AM
grandowneruk
Jun 7, 2010 05:10 PM
