2005 idle low-400 any suggestions, help please
Old Sep 22, 2010 | 08:22 PM
sebringv8's Avatar
Default 2005 idle low-400 any suggestions, help please
my 2005 sebring....mechanic says its the oil pump...but i believe its the low rpms...the oil light dissappears when i hit over 1k rpms....just wondering what could be the problem...lack of power and low idle and i change two o2 senors ....help please and any suggestions please.
Old Sep 23, 2010 | 02:00 PM
Most likely it's the sending unit for the oil pressure. Replace that first. If that doesn't solve the problem, then you might need to tear into the engine, but the sending unit is a cheap and easy repair that should be suspected first.
The idle rpm's are governed by the engine computer. You can't adjust it.
Old Sep 23, 2010 | 05:27 PM
sebringv8's Avatar
i change that also...its just a rpm problem...it goes done and down. it doesnt have a start up problem but its does drop low
Old Sep 23, 2010 | 09:08 PM
Only other part involved in the idle speed is the idle air control motor. If yours isn't operating properly it should generate a fault code.
chengthao85
Jun 11, 2011 03:08 PM
mrorange
Dec 17, 2008 08:37 PM
Esop212
Apr 28, 2008 02:21 PM
startrak140
Sep 20, 2006 01:34 AM
pit0203
Feb 24, 2006 11:00 PM
