2006 chrysler sebring 2.4 engine sedan coolant problems
Old Jun 22, 2011 | 02:08 PM
Diana741100's Avatar
Default 2006 chrysler sebring 2.4 engine sedan coolant problems
Why does the coolant of the sebring hear that it is bubbling after putting water in it.. also the coolant is always low.. i have to check it every 2 days... Please help on how to fix this problem? It hears bubbling the coolant in the container.
Old Jun 22, 2011 | 06:42 PM
Are you putting "water" in there or the proper mix of antifreeze? Have the cooling system pressure checked to see if there's a leak. If so, find it and fix it. Use proper antifreeze as spelled out in the owners manual.
Old Jun 22, 2011 | 09:15 PM
Yes im putting water.. Lost my sebring manual instuctions.. Does anybody know what antifreeze to use?
Old Jun 23, 2011 | 10:13 AM
Download an owners manual at chrysler.com
The cooling system will not operate properly without antifreeze. Plain water will boil out.
Old Jun 23, 2011 | 04:07 PM
100 mile 5 year stuff does it sound like a coffee pot after u shut it off?
Old Jun 24, 2011 | 03:29 AM
i HAVE 90000 ON IT.. YES SIR, IT SOUNDS LIKE A COFFEE POT SOUND AFTER SHOUT IT OFF... Please help!!!
Old Jun 24, 2011 | 09:15 AM
replace the radiator cap the spring is weak and not holding pressure
Old Jun 26, 2011 | 01:29 PM
Im getting a check engine light the code reads PO128.. Ive already added antifreeze coolant.. Help!
Old Jun 26, 2011 | 02:45 PM
OBD-II Trouble Code: P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
"Ive already added antifreeze coolant.." How much did you "add"? Adding in a couple of quarts after pouring in all that water ain't gonna cut it. Since you have no idea what's in there, the only safe thing is to drain and refill.
Old Jun 26, 2011 | 03:11 PM
Ive added 50/50 diluted antifreeze coolant.. Help!
