2006 sebring 2.7 p0202
First of all just want to say hi and thanks for anyone that looks at this post. I just bought this car and saw the p0202 so i swaped out injectors and the injector still did'nt fire. The ECM control wire stays at high voltage and never gives the injector a ground signal. I checked the wire and its good all injectors have good power. I swaped out ECM from a stratus and reset the vin and it started right up but still has the same problem? anyone seen something like this before all the injectors ohms is also good.
how did u check the wires? What were teh readings short to ground ect?
(Post 85299)
Is there anything that can go wrong and fry the used ECM i just put in. |
Originally Posted by Robert Pickering
(Post 85311)
I used a multi meter and put the red lead on power. Then I took the black lead and put it on the wire from the injector coming from ECM all wires but number 2 go to zero volts when you go to crank the motor. Number 2 starts at 12 v and only goes to 10.5 or so. The wire for that injector to ECM ohms where .04 so it should be good. Either way i cut the wire for number 2 injector driver at the ECM harness and it still reads the same when i check it. I took the connector apart at the ECM and its fine.
get a noid lite set Your volt meter is not fast enough to see the voltage drop on the ground side. When cranking it should show a ground pulse on off on off IS the wires shorted to ground did you check for that?
(Post 85322)
then its a pcm issue
(Post 85329)
