2006 Sebring, 2.7, sedan transmission oil
Old Dec 29, 2017 | 10:11 AM
gpatel's Avatar
Default 2006 Sebring, 2.7, sedan transmission oil
Subject: Sebring 2006, tranny oil , v6 2.7, sedan
Hi, merry christmas to you all
I just got my car out of a snow drift and there was a lot of snow under car. I noticed the next day the tranny oil is near empty on dip stick. Qustion, are there any hoses under car that are low enough to be disconected by the snow ? My car is always kept in tip top condition otherwise. Drive appears slow but scarred to tontake it out for long drive, but it is freezing in Ontario now.
Please advise where to best start looking as a lot of snow.
Also is there a LOW transmission oil light on dash to warn of danger?
Sebring 2006, tranny oil , v6 2.7litres, sedan.
Thank you in advance
Gus
Old Dec 29, 2017 | 11:46 AM
REBEL59's Avatar
Top up the trans oil, start it up and look for RED fluid leaking onto the ground. Then look from that general area on the trans. Could have a trans cooler line disconnected or broken.
Old Dec 30, 2017 | 08:09 AM
gpatel's Avatar
Default Transmission pipes to radiator 2.7 sebrimg 2006 ?
THATS WHAT I PLAN TO DO NOW. I DID EPOXY THE RUBBER TO ALLUMINIUM PIPE THAT GOES FROM TRANNY TO RADIATOR LAST SUMMER BECAUSE THE FLARED METAL TO RUBBER COMPRESSION RING WAS LEAKING. I GUESS IT MIGHT BE LEAKING AGAIN. I WANTED TO REPLACE THE 2 PIPES, BUT IF I RECALL, THEY COULD NOT BE REMOVE FROM THE CAR WITHOUT TAKING OUT RADIATOR ETC. HAS ANYBODY DONE THIS JOB AND GIVE SOME TIPS? Also can you make up these pipe parts? Any online part place to order online and part number lookup site?
thanks
Briarly
Dec 29, 2017 10:17 AM
deb963
Dec 10, 2007 10:30 PM
deb963
Nov 11, 2007 08:02 PM
JimboXL
Feb 22, 2007 12:44 AM
