2007 sebring 2.4
I have a 2007 sebring that is showing a misfire on cylinder 1
I've done or checked the following: Installed a remanufactured head after a blown head gasket timing chain and gears Cam position sensors Actuators Plugs Coils Switched the number 1&2 injectors to see if it would misfire on 2 Compression test on all cylinders is 125-130 Any thoughts would be appreciated |
125-130 is low for a hew head and gasket should be in the 150s
Compression
(Post 125149)
pulled the head back off, no scarring on cylinders, filled the valve area with water, no leakage. Only odd thing is that there were no misfires prior to changing the head, gasket and timing chain. |
why did you take the head off the first time?
(Post 125212)
So far so good
Put the new head back on, hooked the timing chain up, 185psi on all cylinders.
HOPEFULLY, it was just the installation or a bad head gasket. I'll let you know. |
