2007 sebring 2.4
Old Aug 28, 2023 | 09:31 AM
Havingfunyet's Avatar
Default 2007 sebring 2.4
I have a 2007 sebring that is showing a misfire on cylinder 1
I've done or checked the following:
Installed a remanufactured head after a blown head gasket
timing chain and gears
Cam position sensors
Actuators
Plugs
Coils
Switched the number 1&2 injectors to see if it would misfire on 2
Compression test on all cylinders is 125-130
Any thoughts would be appreciated
Old Aug 28, 2023 | 08:35 PM
125-130 is low for a hew head and gasket should be in the 150s
Old Sep 2, 2023 | 01:22 PM
Default Compression
I used an endoscope to view the valves and pistons, everything seemed OK.
pulled the head back off, no scarring on cylinders, filled the valve area with water, no leakage.
Only odd thing is that there were no misfires prior to changing the head, gasket and timing chain.
Old Sep 2, 2023 | 02:55 PM
why did you take the head off the first time?
Old Sep 2, 2023 | 03:03 PM
overheating, bad head gasket.
Old Sep 2, 2023 | 04:27 PM
Default So far so good
Put the new head back on, hooked the timing chain up, 185psi on all cylinders.
HOPEFULLY, it was just the installation or a bad head gasket.
I'll let you know.
Nardy30
May 18, 2021 11:07 AM
ilcmb2006
Apr 26, 2018 06:05 AM
luckyboy2007
Dec 9, 2006 09:40 PM
Jun 21, 2006 11:09 PM
