2007 Sebring 4Cyl - 700 and 760 OBD Codes
Old May 20, 2014 | 02:02 PM
sjsalter123's Avatar
Default 2007 Sebring 4Cyl - 700 and 760 OBD Codes
I am getting 700 and 760 codes on my 2007 Sebring, stuck in limp mode (won't come out of 2nd gear).
I looked up the codes and it pointed to a Solenoid pack which I changed to no avail, still same symptoms.
I then bought a multimeter and checked the continuity between pins 4 and 6 of both the old solenoid pack and the replacement. Both registered about 3.5 ohms.
I then disconnected the C1 and C2 connectors from the PCM and checked the resistance between pin 77 on C2 and pin 5 on C1. Resistance showed approximately the same as when just testing the pins on the solenoid pack itself.
To me this says that the solenoid pack and the cables are working correctly and that I should look to replacing the PCM at this point.
Am I looking in the wrong direction at this point?
Thanks,
Shane
Jfizzle
Feb 22, 2020 04:37 PM
shnormo
Mar 21, 2018 08:20 PM
GODFATHER
Apr 12, 2015 08:44 PM
Nik
Mar 21, 2012 03:16 PM
dupek1974
Oct 7, 2009 12:16 PM
