2008 Chrysler Sebring
Old Jul 3, 2011 | 10:49 AM
edwianni1's Avatar
Default 2008 Chrysler Sebring
I was about to try and add R134a refrigerant to my recently purchased Sebring. There is a small circular warning label near where I believe the correct "valve" is located. It stated.... "Do not operate vechicle while AC system is under vacuum"... "Action required / Release Vacuum". I don't know what this means........... and if it really pertains to charging the AC system? Any help would be appreciated. Thank you in advance. Ed.
Old Jul 3, 2011 | 03:29 PM
1) Don't add refrigerant just for the sake of adding refrigerant. How have you decided that it needs refrigerant? How do you know how much to add?
2) The only place to add refrigerant is at the low side tap. It will be the only place the kit can fit.
3) The proper way to charge an A/C system is to first suck all the old refrigerant out, then subject the system to a vacuum to remove moisture. Usually, you apply the vacuum for a period of time, like 20 minutes to get as much moisture out as possible. During that time, you should not operate the engine, per the warning. If you MUST run the engine, you should release the vacuum, which means you'll have to go through the process again before filling the system with the proper amount of refrigerant.
Old Jul 3, 2011 | 07:20 PM
edwianni1's Avatar
Thank you. Now it makes sense.
jt1968
Jan 21, 2011 10:07 AM
cstingray
Nov 1, 2008 10:42 PM
clermann
May 2, 2008 12:27 PM
clermann
May 2, 2008 12:25 PM
Jan 10, 2006 06:03 AM
