2008 sebring convertible
Old Jun 10, 2022 | 10:25 AM
kschnell's Avatar
Default 2008 sebring convertible
Has anyone replaced the rear window in there 2008 or similar rear window. I am looking for a replacement and all I can find is for a 4dr. Are these the same and does it have to be installed professionally?
Thanks for any info.
Old Jun 10, 2022 | 01:56 PM
They are absolutely not the same part. Is yours a soft top or hard top convertible? If a soft top, try visiting a shop that specializes in convertible tops. If a hard top, try a collision shop. Unless you're experienced in replacing these, you don't want to do it yourself. It's a skill that is learned by practice. Find someone who does it all day every day to get it done right.
Old Jun 11, 2022 | 10:03 AM
ggoose's Avatar
The convertible back glass is NOT the same as the sedan. The part number is MOPAR 68027039AB. A body/glass shop should be able to get a replacement. The convertible back glass from any 2008+ convertible will fit both softtop and hardtop.
The convertible back glass replacement for 2008+ is similar to a standard windshield or sedan replacement. Reason for having a professional install is using the proper caulk, getting the caulk bead the proper width and setting the glass on the top without any movement that would smear/compromise the caulk bead and reduce the integrity or adhesion strength of the caulk.
Rcbulldog1983
Sep 26, 2021 02:48 PM
TonyW
Jun 18, 2015 05:15 PM
tdb
Sep 9, 2014 09:35 AM
clermann
May 2, 2008 12:27 PM
Jan 10, 2006 06:03 AM
