2010 Console 12v output dead. Which fuse.
Old Feb 17, 2021 | 03:32 PM
JLOB's Avatar
Default 2010 Console 12v output dead. Which fuse.
My wife's 2010 Sebring convertible console-mounted 12v outlet no longer works. The dash unit does, but the wattage on my oxygen concentrator often blows that fuse. We've had no problem, until recently, with the 12v in the arm-rest console. Since it seems to be dead, I'm looking for advice on which fuse to try. The mini-fuses all look good. Does anyone have a lock on which fuse supports that outlet?
Thanks. It's sort of important. We can't travel very far in her car without that power
JLOB
Old Feb 17, 2021 | 04:21 PM
Which fuse controls which component is inscribed on the underside of the cover of the fuse box. Similar information is found in the owners manual. Owners manuals can be downloaded from chrysler.com.
Failing that, trial and error should reveal a blown fuse, if that is the problem. Just because a fuse "looks good' doesn't always mean that it is good. There could be a wiring problem that is causing the outlet not to work. Unfortunately, outlets buried in the console are sometimes the dickens to access for repair.
Old Feb 17, 2021 | 11:26 PM
ggoose's Avatar
sfry77
Oct 23, 2021 03:21 PM
Thatdudestl
Jan 10, 2018 10:44 AM
keely111
Jun 8, 2011 04:45 PM
jacktar57
Apr 11, 2011 12:12 PM
Shank68
Jan 23, 2011 10:28 AM
