2010 wont stay started, etc light is on
Old Apr 4, 2014 | 12:56 PM
pwalke773's Avatar
Question 2010 wont stay started, etc light is on
My 2010 Sebring wouldnt start, we jump started it and it ran for a few minutes and then the ETC light came on, the car started shaking, wouldnt move out of gear and the car died.
Can't seem to find the part at an autoparts store, is this a chrysler part only that I'll have to get from a dealership?
Old Apr 4, 2014 | 03:35 PM
are u trying to replace teh throttle body? then yes dealer only part and dealer will need to program it once installed. FYI have u checked teh codes with a scanner first?
Old Apr 14, 2014 | 02:53 AM
fhadso's Avatar
Get in the car, shut the door, put in the key, and do what is called the "key dance". From off, turn it on, off, on, off, on within ten seconds. The trouble codes should appear in the odometer. Otherwise, take it to autozone/oreily's/the dealership to get the codes pulled. Be warned if you take it to a dealership, they will charge you to pull the codes. Is it a 2.4,2.7, or 3.5? I believe they only used the 3.5 and the 2.4 in your model year, so I might be off in my guesses.
Old Apr 14, 2014 | 09:37 AM
key dance inop on 2010 cars they took that software out in 04 and up new designs ugggg
Old Apr 14, 2014 | 03:45 PM
Let's eat Grandma.
Let's eat, Grandma.
Proper punctuation saves lives.
Old Apr 14, 2014 | 09:27 PM
notinthismatterstillsameoutcome
Old Apr 15, 2014 | 05:05 AM
pwalke773's Avatar
So after replacing battery and alternator and still no charge we've ordered an ecu, if it came from the same model year and engine will it still have to be programmed by Chrysler? Thanks for your time, its nice to have the input.
Old Apr 15, 2014 | 09:42 AM
Dude. You're just throwing parts at it and you are starting with the most expensive parts first. That's not a good approach to car repair. And yes, you will need to have the computer programmed with the VIN and mileage.
Did you ever get any fault code out of the old ecu?
Old Apr 15, 2014 | 10:17 AM
Im gonna say no
Old Apr 16, 2014 | 07:07 AM
pwalke773's Avatar
"Dude" no, I am not just throwing parts at it, when the battery wouldnt hold a charge and was tested, it had a bad cell. Replaced. Secondly, when the voltage was tested at the alternater itself, it had 0 amps, took it in to our local guy for repair and he showed me exactly the problem.......also reminded me that my alternator was electronic and charged from the ECU and if it was still not charging, it was an ECU problem. Thirdly, the ECU was throwing codes there were no problems with, indicating it was an ECU Problem also. Thank you for your insults and lack of help in answering my question, feel free to offend someone else today and don't worry about my problem, I got your message loud and clear.
