2016 Chrysler 200 variying brake sensitivity
Old Jun 13, 2018 | 10:47 PM
Jessica Strawbridge's Avatar
Default 2016 Chrysler 200 variying brake sensitivity
Hey guys, I bought a used 2016 Chrysler 200 back in April of last year. I’ve noticed that usually when it’s raining but not limited to that, my brakes tend to be less sensitive and at times I would almost have to floor the pedal to get it to stop. Has anyone else had this issue. I’ve been putting it off taking it to the dealer since they are over an hour drive from where I live.
Old Jun 14, 2018 | 12:24 PM
If you drive through a deep puddle you should expect the brakes to be less effective. Wet brakes don't work as well as dry ones. Sometimes dramatically so. If you are also noticing it when wetness is not a factor, then you may be having a problem with the power brake booster.
Intermittent problems can be very hard to diagnose correctly. If you can, keep track of exactly when and under what circumstances the problem arises. It may help the technician come to a proper diagnosis. Unless you're still under warranty, it may work out better for you to go to a reputable local shop rather than driving an hour to the dealer. Ask around for recommendations.
waterpirate
Sep 5, 2024 02:34 AM
retnav99
Sep 11, 2016 06:32 PM
vega43
Oct 20, 2014 10:07 AM
jayroc7113
Dec 20, 2013 05:38 PM
reksav
Dec 14, 2010 01:48 PM
