-   -   3.0 will not run in the rain (https://www.chryslerforum.com/forum/chrysler-200-sebring-14/3-0-will-not-run-rain-8937/)
bcartman_2 Jul 30, 2009 01:38 PM
I have an 02 Sebring with the 3.0L engine, it has a hard time starting in the rain, on top of that it will just stop running at any time while I am driving, no sputter or warning it just stops. It throws two codes once in a while, the first is a knock and the second is the crank position sensor wiring error. I have replaced the crank trigger and the problem went away for about a month and is now back, I have heard that the cam sensor can cause a fault with the crank sensor, is that true? Anybody have any experience with this? Where do I check next?
PS all of the connectors are tight.
dcotter0579 Jul 30, 2009 07:34 PM
Have you checked your fuel pump? ASD relay?
