3.0 will not run in the rain
Old Jul 30, 2009 | 01:38 PM
bcartman_2's Avatar
Default 3.0 will not run in the rain
I have an 02 Sebring with the 3.0L engine, it has a hard time starting in the rain, on top of that it will just stop running at any time while I am driving, no sputter or warning it just stops. It throws two codes once in a while, the first is a knock and the second is the crank position sensor wiring error. I have replaced the crank trigger and the problem went away for about a month and is now back, I have heard that the cam sensor can cause a fault with the crank sensor, is that true? Anybody have any experience with this? Where do I check next?
PS all of the connectors are tight.
Old Jul 30, 2009 | 07:34 PM
Have you checked your fuel pump? ASD relay?
hightech24
Aug 26, 2011 03:44 AM
tdavetice
Jul 25, 2010 10:38 AM
lilpengwen
Sep 11, 2009 02:37 PM
Aquinas
Apr 18, 2007 01:59 AM
Nov 16, 2005 04:58 PM
