3.5L transverse engine removal
Old Apr 22, 2020 | 02:17 AM
Weirdo's Avatar
Default 3.5L transverse engine removal
I cannot find any definitive information on how to remove the 3.5L engine from my 2007 Sebring Limited. This is a "M" code on the VIN tag. It is mounted transverse, NOT inline. Automatic transmission. Timing belt broke and damaged valves on both banks. So I want to pull the engine to either rework the heads or just swap in a different engine. Thanks in advance.
Old Apr 22, 2020 | 08:43 AM
REBEL59's Avatar
yours should be NO DIFFERENT than the 08-10 3.5 Avenger/200 models. Same platform, same process. A lot depends on what equipment you have to work with, Many techs would rather drop out the front sub frame and remove engine/trans as a unit for such repairs as you describe.
Good Luck!
Old Apr 22, 2020 | 11:45 AM
Weirdo's Avatar
Rebel59- Thanks for your quick response. I do not have access to a car lift but I do have a good engine hoist. I was hoping lifting the engine was a possible solution. I'll investigate the Averger/200 forums. I was not aware they were similar platforms. Seem these 3.5 Sebring's are few.
cnc
Mar 17, 2015 12:24 PM
Morkon
Sep 29, 2013 10:49 PM
bigfred
Apr 25, 2011 09:43 AM
bigfred
Apr 24, 2011 08:07 PM
sebringphanatic
Jul 25, 2009 12:03 AM
