#4 cyl missing
Old Jul 28, 2009 | 10:49 PM
derek61's Avatar
Smile #4 cyl missing
hello , i have a 2001 sebring conv. 2.7 liter , # 4 cylinder not firing , it has a coil for each cyl. i tried swapping coils around no help , i have 13 or so volts going to the green wire on the coil but nothing on the brown wire , i think its supposed to be a pulsing ground?,i tried the other two cylinder coils up front and the brown wire pulses on ohms, nothing on # 4 , does this mean i have a bad ECM?, ive found remanufactured ones on ebay for 199.00 i dont mind spending the money , but just wanna make sure thats what it is , im just not very famalier with this type of ignition system , any advice would be appreciated , and by the way the car has 93,000 miles thanks
Old Jul 29, 2009 | 08:39 AM
brown wire is a ground pulse yes do u have that?
Old Jul 29, 2009 | 06:22 PM
derek61's Avatar
Default ground
no i have no pulsing ground on the brown wire on # 4 cylinder and thanks for the help , would this be the pcm or the ecm? this is bugging the crap outta me,,,, were pretty close we live close to bham alabama
Old Jul 29, 2009 | 07:44 PM
Check the wiring carefully before you replace the PCM.
Old Jul 29, 2009 | 08:35 PM
derek61's Avatar
thanks ill definitly do that because the problem started a couple weeks ago ,intermitently and now it misses on that #4 cyl all the time
Old Jul 29, 2009 | 09:50 PM
yes chk wires b4 pcm replace 9 times out of 10 the pcm is not the prob.
jbighua7
May 22, 2009 11:06 PM
joefisch
May 22, 2009 08:03 PM
railroader
Jul 15, 2007 08:29 AM
Dominator326
Apr 26, 2006 04:27 PM
E85Fan
Mar 20, 2006 02:45 PM
