96 JX Cluster issue
Old Apr 23, 2007 | 08:01 PM
cjsilvay's Avatar
Default 96 JX Cluster issue
Hello, my 96 JX convertible is having an issue with the instrument cluster, the RPM gauge and the odometer turn on and off randomly and now it seems there is a short some where because it drains my batteriw at night, the odometer still registers the milage when it lights up, o and i get the word "deck" above the odometer when it does come on, like where it says "door" when ur door is open, anyway i was wondering if anyone knows what the "deck" means or if ya have any ideas on where the short may be cause im positive its not behind the cluster itself, thanks
Old Apr 23, 2007 | 08:12 PM
Default RE: 96 JX Cluster issue
well looks like either 2 issues or just one the DECK is your trunk lid open if the lid ois open or the ajar switch is not woorking right then the light will stay on and kill your batt. U can check for yourself ahve some one close u inside the trunk and see if the light goes out or not if yes then move on if not fix the latch , or an adj is needed to make sure the trunk closes all the way. Next issue The cluster i have seen do the rpm dance and also make the cluster stay awake and kill the batt as well.
Old Apr 23, 2007 | 09:11 PM
cjsilvay's Avatar
thanks man, that reminded me that about a month ago i have to take the trunk latch off because it got stuck and wasnt closing, ill check the grounds and stuff to make sure thats what is killing the batterie, thanks again, ill get back if it works or not.
Old Apr 23, 2007 | 09:24 PM
unless there is a short to ground on the tn/bk wire it wont be a ground issue.
Old Apr 24, 2007 | 04:04 PM
Logiks's Avatar
Ah no. You got the famous Tach/Odo problem. The other forum has the precise procedure to give this a fix if you own a sodering iron. Here you go:
http://www.sebringclub.net/gallery/TachRepair
The forum pages:
http://www.sebringclub.net/board/viewtopic.php?t=1970
that should do it.
-Rob
koolhut
Apr 6, 2013 02:54 PM
94_LHS
Aug 1, 2006 02:24 AM
proc
Mar 14, 2006 12:02 AM
sulup
Nov 23, 2005 10:48 AM
sulup
Nov 23, 2005 10:44 AM
