96 jxi alternator belt tension adjustement
There is an adjusting bolt under the belt tension pulley. When I am turning it in or out it does nothing to the tension of the belt. I need to remove the alternator and have it bench tested. What should I do to release the tension w/o damaging anything?
because there is a second bot u must loosen first then the adj bot will allow it to move
where is that second bolt located? Please be specific, there is very little room and hard to see.
its on the pulls itself the same on you are turing the adjusting bolt on
