96 Sebring 2.4 Idle issue
Old Jun 7, 2012 | 05:36 PM
GaryRoe's Avatar
Default 96 Sebring 2.4 Idle issue
Won't idle at all, 180 lbs compression on all cyl. Injectors and fuel pressure fine. Revs and sounds great. Used starting fluid everywhere, no vac leaks.
EGR moving. No codes. Put in new coil, wires and plugs just because. What next??????
Old Jun 7, 2012 | 08:06 PM
better description to wont idle at all
Old Jun 7, 2012 | 08:56 PM
GaryRoe's Avatar
Holding the accelerator pedal over 1000 rpm, let the pedal down slowly it dies
before reaching 800 RPM.
Old Jun 7, 2012 | 09:58 PM
"What next??"
Dirty throttle body? Clean it.
Idle air control motor. Check it.
Old Jun 7, 2012 | 10:05 PM
GaryRoe's Avatar
"What next??"
Thanks, I'll try that tomorrow.
Rubber coupler, resonator to throttle body, ripped, dealer said good luck !!!
Old Jun 7, 2012 | 10:38 PM
oh that's your issue right there or part of it U must have a tight seal in that area for it to work
Old Jun 8, 2012 | 07:36 AM
GaryRoe's Avatar
Part available anywhere you know? THANKS FOR THE HELP !
Old Jun 8, 2012 | 07:37 AM
GaryRoe's Avatar
Also, why no codes ???
Old Jun 8, 2012 | 10:23 AM
cant help with parts call around your area
Old Jun 8, 2012 | 02:33 PM
TNtech's Avatar
Because there is nothing measuring the volume of air coming through. Just temperature.
70 roadrunner
Dec 3, 2014 07:48 AM
curt_wells@earthlink.net
Jul 29, 2011 09:00 AM
GOLD G Ride
Apr 27, 2010 04:00 PM
phat1101
Mar 21, 2010 04:16 PM
macfarlane300
Feb 2, 2009 09:00 AM
