97-98 Convert vs Coupe Engine Compatability
Old Mar 22, 2008 | 06:14 PM
phincenzo's Avatar
Default 97-98 Convert vs Coupe Engine Compatability
I have an issue. I have a 1997 Sebring Convertible that was diagnosed by a mechanic as having bent pistons (engine makes terrible thudding noise when turned on) and suggested to replace the engine. The convertible is 2.5 V-6 Convertible JX. I bought a 1998 Sebring Coupe LXI 2.5 V-6 to replace it. When reading the instruction manual, it states for the 97 Convertible raise the car off the engine to remove the engine. For the 98 Coupe it states raise the engine out of the car. When looking at the two engines, the mounts seem in different places. So my concern is whether this 98 coupe will fit into the 97 convert. Am I going to have to modify the engine mounts on the coupe or is this engine just not going to fit? YOur expertise will be helpful. Thank you
Old Mar 25, 2008 | 07:56 PM
rjasp2000's Avatar
Default RE: 97-98 Convert vs Coupe Engine Compatability
Hi I just wet to www.car-parts.com and typed in your car and it doesn't show that a 98 will fit.Check it out for yourself,it showed 97 and down and the 98 was 98 and up.
scott m
Jan 31, 2012 04:43 PM
gallam03
Oct 1, 2009 08:26 PM
gallam03
Oct 1, 2009 02:12 PM
sebringphanatic
Jul 25, 2009 12:03 AM
ragtop71
Jul 13, 2006 03:54 PM
