98 convertible
was driving my jxi yesterday stopped at the store came back out and it did not start everything works lights radio etc just no crank..
got it towed home 10 miles off the tow truck and it started right up knowing it did not fix itself drove it to my buddies house down the road no problem drove fine after an hour went back to start it nothing same as before i left it at my buddies house any ideas would be greatly appreciated thank you |
[quote=hoss;58326]was driving my jxi yesterday stopped at the store came back out and it did not start everything works lights radio etc just no crank..
got it towed home 10 miles off the tow truck and it started right up knowing it did not fix itself drove it to my buddies house down the road no problem drove fine after an hour went back to start it nothing same as before i left it at my buddies house any ideas would be greatly appreciated thank you just an update went to my buddies this morning car started right up try to scan no codes drove it home just tried to start it again and again nothing could it be the starter? |
Might be the starter relay. Might be corrosion in the cables leading to the starter.
Might be the key switch or anywhere between it and the starter. Get your volt-ohm meter out and start checking for continuity and voltage everywhere you can. |
Originally Posted by hoss
(Post 58326)
thank you where is the starter relay on this model
it is not in the pdb under the hood |
update found the relay !! switched it with another one in the box still nothing
in 15 years doing electrical and diriveablity never had to replace a relay for any issue.
Check for spark and fuel I am gonna guess u have a bad distributor assembly |
I think, we are talking about different relays. I'm talking about relay on the starter.
http://www.sgmarket.ru/images/hotpotbig04.jpg |
no I am quite aware of what relay u are talking about it would be in a little black box beside the longer fuse box under the hood.
I got the impression he was saying it wouldn't crank.
| All times are GMT -5. The time now is 06:33 AM. |
