99 sebring A/C clutch
Old Jul 11, 2014 | 09:12 PM
RichyRich001's Avatar
Default 99 sebring A/C clutch
Bearings went out on my A/C clutch. My question is, do I have to take the compressor all the way out to change it? Or can I leave it hooked up, remove the belt, replace the clutch and be done with it?
Old Jul 11, 2014 | 10:01 PM
If you have the right tools, you may be able to pull the clutch without disconnecting the compressor from the system, though you will probably need to un-mount the compressor from its supports. It's pretty tight in there. Work carefully, you don't want to send a wrench through the radiator.
Spend 25 bucks for a shop manual like a Haynes if you're going to tackle a job like that.
Old Jul 12, 2014 | 12:49 AM
Do I have to get all of the Freon out first, or can I leave the system closed up. And, it seems as though no one sells just the A/C clutch. Everyone wants you to buy the whole compressor unit. Or does it make since to replace the whole unit?? Just replaced all of that about 2 years ago.
Old Jul 12, 2014 | 08:17 PM
If you can pull the clutch and replace it, then there's no need to open the system, but if you can't find a replacement clutch, then it's a moot point.
jimG
Sep 6, 2019 05:27 AM
beck4368
Jan 16, 2012 06:50 AM
genoaz
Sep 16, 2011 09:10 AM
Inverted
Aug 7, 2010 02:43 AM
jadenstate
Jan 29, 2010 09:44 PM
