AC comes on when lights turned on
Old Oct 15, 2013 | 08:13 AM
jimhodge's Avatar
Default AC comes on when lights turned on
I have a 2001 sebring Convertable and the AC compressor comes on and blowes out thru the defrost when i turn on my head lights. I'v tried to recalibrate the control panel but that doesn't work. As long as my lights are off the control panel works fine. Also when lights are on my defrost doesn't work. This is about to drive me crazy. Any advise whould be welcomed.
Old Oct 15, 2013 | 09:07 AM
Is your battery in good shape? A low battery can cause weird things to happen in these cars where everything is run through the computer. If the headlights are straining an already weak battery, that might be part of the problem.
I don't believe the recalibration maneuver works in the 2001 model. But I think it's possible to initiate a recalibration sequence by disconnecting the battery for a minute or so.
Old Oct 15, 2013 | 01:01 PM
jimhodge's Avatar
Yes the battery is new. I'm going to try to disconnect the battery and give that a try. Thanks for your imput.
Old Oct 15, 2013 | 01:47 PM
jimhodge's Avatar
I disconnected the battery and waited a few minutes. When I connected the battery back the ac still comes on when i turn on the head lights.
Old Oct 15, 2013 | 03:30 PM
The body control module is involved in the headlight operation for the delay-off feature and for the high beams. As far as I can tell, it shouldn't be part of the normal headlight operation. It is, of course part of the heater-A/C control.
My best guess is that the body control module has some sort of internal issue. It's a computer so who knows what is going on.
Old Oct 17, 2013 | 07:51 AM
jimhodge's Avatar
Found the problem, The AC control panel was defective. I went to a salvage yard and purchased a used panel and it works great. Now i have heat when lights are on.
mikemichele819
Jan 14, 2015 02:43 PM
bate1
Jan 3, 2012 08:46 AM
needhelpnow2321
May 17, 2011 10:18 PM
cashew1
Jun 22, 2007 09:07 AM
latreto
Jan 30, 2007 10:12 AM
