battery location
I have recently bought 96 sebring convertible. I am trying to find the battery so I can determine how old it is. What in the world do you have to remove to see the battery? And how do you do it. This is crazy, I have never seen a vehicle where the battery is not right on top.
RE: battery location
the location of the battery is under the driver side fender well. With this location it is away from heat and lasts longer then them being on top.
I had to replace the Battery in my 1997 Sebring. What I did was, removed the Front left tire and then remove the screws that hold the Battery cover on. Once that is taken off, your battery may have a battery warmer around it (I have no idea if they are standard on these cars) Then unplug the negative terminal first (to avoid short circuiting, atleast thats what I was told) and finally, the positive terminal.
